rock1 Posted February 1, 2012 Posted February 1, 2012 How can i use subtract area command in area command while using add command , often it happens we click on polyline whose area we did not want to consider. How can i do like this, i re click on that enclosed polyline and the area gets subtracted and the green fill goes away? Quote
MSasu Posted February 1, 2012 Posted February 1, 2012 Please check that along Add option you have Subtract option, too - you can switch between those modes. Simply press once to end the Add mode, input "S" to go in Subtract mode, remove what you need and go back to Add mode. Regards, Mircea Quote
