I'm new hear so forgive me if i'm asking this in the wrong place. I need to export the areas of multiple closed polygons to excel and update that excel as soon as the areas change. We've been using an outside contractor who is able to do this using land f/x. Just wondering if anyone has come across any other software that may help with this.
Thanks in advance.
D.
You can use fields or you will need to write some visual lisp if you want to do this in Autocad
Dataextract may do it for you, there are lots of lisp out there may do it as well. Now if you want a software program that do that and more look at AutoCAD Map3D.
