I'm running into a problem today setting up a drawing. The drawing has three viewports at different scales all looking at different parts of a model I have xrefed. The problem is that when I set a viewport to 1" = 50' for example, it is really being set to 1" = 50" -- off by a factor of 12. I cannot figure out where this problem stems from, but it is driving me a little crazy at the moment. I can work with it, by setting the scale with this correction factor in mind, but I would rather be able to set my viewports correctly, in case someone uses this drawing later as a go by or to do revision work.
Has anyone else run into this problem before? Or am I overlooking something simple?
change your drawing units to feet and inces instead on inches.
