alijahed Posted October 22, 2008 Share Posted October 22, 2008 Hi All, I have really basic question. I put my question on the file. Cheers Ali Drawing2.dwg Quote Link to comment Share on other sites More sharing options...
lpseifert Posted October 22, 2008 Share Posted October 22, 2008 Break command Command: break BREAK Select object: Specify second break point or [First point]: f Specify first break point: int of Specify second break point: @ or... if you do it a lot (defun c:brk-at () (setq e1(entsel "Select object: ")) (setq os(getvar"osmode")) (setvar "osmode" 33) (command "break" e1 "f" pause "@" ) (setvar "osmode" os) (princ) ) Quote Link to comment Share on other sites More sharing options...
alijahed Posted October 22, 2008 Author Share Posted October 22, 2008 Break commandor... if you do it a lot (defun c:brk-at () (setq e1(entsel "Select object: ")) (setq os(getvar"osmode")) (setvar "osmode" 33) (command "break" e1 "f" pause "@" ) (setvar "osmode" os) (princ) ) Cheers mate Quote Link to comment Share on other sites More sharing options...
