DS-precast Posted February 8, 2012 Share Posted February 8, 2012 (edited) I have a macro attached to a button to make duplicate copies of a dynamic block at regular spacings. (See http://www.cadtutor.net/forum/showthread.php?66102-How-do-I-get-copy-macro-to-end-by-selecting-the-newly-copied-item) It works fine when using the World co-ordinate systems and copying in the Y direction. However when the initial block is at an angle, I change the UCS to align with this object, and then try to copy blocks using the macro. The results baffle me, because it works ok sometimes, but most of the time the spacings do not correspond to the macro. Is there an easier way to do this, or are there any settings that I need to check to make it work? Macro below : ^C^C_.Copymode;1;_.Copy;P;;D;0,525;select;L;;_.Copymode;0 Can anyone help please? Edited February 13, 2012 by SLW210 CODE TAGS! Quote Link to comment Share on other sites More sharing options...
BIGAL Posted February 13, 2012 Share Posted February 13, 2012 (edited) When you change the UCs are you introducing a z into the new UCS ? we had problem with UCS OB on 3d lines. else maybe copy;select;0,0 0,525 Edited February 13, 2012 by SLW210 Quote Link to comment Share on other sites More sharing options...
SLW210 Posted February 13, 2012 Share Posted February 13, 2012 DS-precast, Please use CODE TAGS in the future for Macros. I fixed it for you this time. Quote Link to comment Share on other sites More sharing options...
DS-precast Posted February 16, 2012 Author Share Posted February 16, 2012 BigAL - Thanks for your reply There is no Z element in the UCS. I need to be able to repeatedly put in copies of the dynamic block at three standard spacings (three buttons) without re-selecting the block each time. Quote Link to comment Share on other sites More sharing options...
