Hello to all,
i would like to know if a routine such as a wipeout exist but with the possibilty to use arc pline.
such as when you make the command pline you have the fallowing choices.
arc/halfwidth/lenght/undo/width
I would only like to have the arc option.
thanks in advance for the help.
Cheers & Beers
No but you can simulate it with the polygon command.
An example would be: If you use a circle for the starting shape then use POLYGON with say 100 sides then choose the center of the circle for the center of the polygon and then choose the Inscribed option you will have a circle made up of many segments.
It will take a few more steps (i.e. place a circle at each arc on your polyline then use the process I described then trim the new simulated arc) to produce the same for your problem but it is doable.
Thank Lee !
I never think of looking on TheSwamp hehe dont know why.
WOW! :shock:
I wished I had asked about this a long time ago. Sure would save me a lot of time. This is one reason I love this community.
Once again Lee Mac shines through the darkness. :notworthy:
WOW! :shock:
You're welcome :)
Its gile you need to thank, I just passed on the link ;)
You're welcome :)
Indeed. I shall do just that. The thanks is for sharing. :thumbsup:
