extracting LOGINNAME to place in to a drawing title
Since you're in turbo mode.. write one for (vlax-get-or-create-object "VBScript.RegExp") for the fun of it ;)
Just for the fun of it :)
(defun test ( str / regex )
   (if (setq regex (vlax-get-or-create-object "VBScript.RegExp"))
           (setq str
               (vl-catch-all-apply
                   (function
                       (lambda ( )
                           (vlax-put-property regex 'pattern "^(.)[^.]*\\.(.*)$")
                           (vlax-invoke-method regex 'replace str "$1.$2")
           (vlax-release-object regex)
           (if (null (vl-catch-all-error-p str))
               (strcase str)
(vl-load-com)
_$ (test "Daniel.Williams")
"D.WILLIAMS"
  • Replies 23
  • dannywi77iams
    7
  • pBe
    6
  • MSasu
    5
  • Lee Mac
    3
"D.WILLIAMS"
Cool beans :thumbsup:
Thanks Lee
Cheers
Here is my finished code for now. I'll may end up changing it someday.
(defun c:l2t ()
 (setq usernm (strcase (getvar "Loginname")));"Daniel.Williams"
 (setq fstin (strcat (substr usernm 1 1)); Split usernm to find first name inital "D"
surnm (last (fnsplitl usernm)); Split usernm to find surname ".Williams"
surin (strcat (substr surnm 1 2))); Splits the surnm to find the surname inital ".W"
;;;  ********    Create names:    ********
 (setq tilnm (strcat fstin surnm)); Create title name ("D.WILLIAMS")
 (setq revin (strcat fstin surin ".")); Create inital name ("D.W.")
 ); end
You may define the variables that aren't needed outside your routine as local to avoid interference with other codes:
(defun c:l2t ( / [color=blue]usernm fstin surnm surin[/color] )
 ); end
Are you going to use this on command prompt or inside an AutoLISP routine? For the second case I suggest to define a function instead of a command.
Regards,
Mircea
