John1951 Posted February 10, 2012 Posted February 10, 2012 Hello I need to be able to renumber a series of text objects, (all the text are numerals) I wrote some code that works if none of the text objects are erased. If I erase one of the text objects, the code still works, but if I erase another I get Run Time error Method Item of object IAcadSelectionSet failed. at this line in the code: Set returnObj = ssetObj.Item(i&) (i& is a valid number for the selection set) I noticed that ssetObj.Count remains equal to the original number of text objects before any where erased. I think that these erased or phantom objects are causing the code to crash. I get the text objects using a filter for Text. FilterType(0) = 0 FilterData(0) = "Text" ssetObj.SelectOnScreen FilterType, FilterData The example dwg has only the text that I am using to try the code, there are no other objects in the drawing. Any ideas? Thank you John Quote
