afrazawan Posted February 13, 2012 Posted February 13, 2012 hi guys i want to make Road Longitudinal Profile kindly i need any software for help to create profile in easy way kindly im using Auto CAD so i need any other application thanks Auto CAD created sample attached! BHE DLP 007{DETOUR PROFILE ( IP-41711 Layout1 (1).pdf Quote
CyberAngel Posted February 13, 2012 Posted February 13, 2012 Someone posted this LISP routine a while back. http://www.cadtutor.net/forum/showthread.php?30069-Cross-section-From-Plan&highlight=quickprofile+lisp Quote
f700es Posted February 13, 2012 Posted February 13, 2012 You can also try CADTOOLS. That is free? Sweet! Quote
Cad64 Posted February 13, 2012 Posted February 13, 2012 I'm sure you don't mean that you want people to "give you software", right? You want people to give you suggestions for which software to use, correct? Quote
memphis710 Posted February 13, 2012 Posted February 13, 2012 That is free? Sweet! Have used this for a while... Excellent free tool. Now have a batch file to load CAD and Cadtools at the same time as I use it so often... Quote
f700es Posted February 13, 2012 Posted February 13, 2012 I would imagine so, probably a language error. I'm sure you don't mean that you want people to "give you software", right? You want people to give you suggestions for which software to use, correct? Quote
Jack_O'neill Posted February 13, 2012 Posted February 13, 2012 I'm sure you don't mean that you want people to "give you software", right? You want people to give you suggestions for which software to use, correct? I dunno...if somebody had a pile of money they didn't need and wanted to buy a copy of Inventor for me, I'd let um!! Quote
afrazawan Posted February 14, 2012 Author Posted February 14, 2012 Please help me how to run cad tool in auto cad 2012 how it will work pls help me i installed already but how to start it thanks Quote
Organic Posted February 14, 2012 Posted February 14, 2012 Cadtools is a pretty decent tool and the guy behind it updates it regularly. I wouldn't design a road with it personally though, certainly not one as complex as what is in that pdf with vertical curves and superelevation. You can always download the trial version of AutoCad Civil 3D etc. Cadtools works fine for me with AutoCad 2012. Quote
SLW210 Posted February 14, 2012 Posted February 14, 2012 Should be listed in Start>Programs>CadTools>CadTools.exe. I pinned it to the TaskBar. Quote
BIGAL Posted February 16, 2012 Posted February 16, 2012 A tradesman is often only as good as his Tools if he wants excellence then better quality of tools may be necessary. Quote
