Tesjay
"Coordinate dimensions"
Tesjay
  1. In autocad 8, how could I get the XYZ coodinates of a point, on the drawing. With ID or list command it is possible to get the coordinates of a point, but they would not appear on the drawing the way dimensions do.
Share this post
Link to post
ReMark
You could use a custom lisp routine. That would be one option.
Share this post
Link to post
SLW210
MTEXT with a field.
Share this post
Link to post
Dadgad
If you create an Mtext. and insert a field in the right click menu to specify the object and location it will display the coordinates, per SLW210's suggestion.
You probably want to set a DDPTYPE for you point first, so you can see it, as I have.
Share this post
Link to post
ReMark
Can it be set up to display Northing and Easting? Example: N202,456.73, E67,339.01
Share this post
Link to post
Dadgad
I am clueless as regards northing and easting, but if you assign geographic values to your drawing you could get it to display longitude and lattitude.
I made a simple Mtext, and couldn't get it to display better than this, but with a multiline text you could.
Share this post
Link to post
ReMark
Many state plane coordinate systems utilize northings and eastings not latitude and longitude. I was just curious. In my job I seldom encounter these types of situations and if I do I use a custom lisp routine that adds the "N" and the "E" designations to the front of the coordinate.
Share this post
Link to post
eldon
Once you get into Mtext with fields, don't be too greedy and get the position x, y and z all in one go. Format as desired. These are based on the Insertion Point (Top Left)
Share this post
Link to post
ReMark
eldon is on a tear today. He's just knocking these babies out of the ballpark.:lol:
Unnecessary
Edited by SLW210
Share this post
Link to post
Murph_map
How about creating a block to display it and insert the blocks where you need the text/labels. :)
http://www.lazydrafter.com/autocad-tips/create-a-northing-easting-block-with-fields
Share this post
Link to post
Dadgad
......couldn't get it to display better than this, but with a multiline text you could.
That's more to the point Eldon, nicely done.
The first one I did was directed to the OP's inquiry, this plays beautifully to the Northing & Easting question. :beer:
Share this post
Link to post
Create an account
Register a new account
Sign in
Sign In Now
