niall mcginnis Posted October 23, 2008 Posted October 23, 2008 hi, i having a problem with inventor 2008. not all the time but some times it saves the drawings with file name newVer stuck on the end.once it has saved in this format it will not let me open it. it gives me the thumbnail but will not open. it gives no reason for not opening. iam lost thanks in advance nially Quote
Aardvark Posted October 23, 2008 Posted October 23, 2008 This is because the program crashed and Inventor made an attempt to save your data. What you need to do is rename the ORIGINAL file (i.e. add a letter to the file name, anything will work.), then remove the .newver extension from the new file so that the file name is the same as the original file that you just changed. Open the new file and you should be good to go. Sometimes the data is too corrupted to retrieve and this does not work. In that case, retrieve a copy from the oldversions folder and start over. Quote
niall mcginnis Posted October 24, 2008 Author Posted October 24, 2008 cheers, ill give that a try niall Quote
