I have an issue with the VisualLISP editor – after load the code from current edited file to AutoCAD the editor’s title bar change to something like "[File.lsp loading…]" and I’m not allowed anymore to modify the code. The code inside the edited file is executed entirely without error. If I try to load again the code the title bar become like "[File.lsp loading… loading…]" – the code is executed.
This error (title bar message and "read-only" mode] persists randomly after I close and restart AutoCAD.
Other files that are opened in VisualLISP editor aren’t affected.
I someone encountered this issue before, I will appreciate if can help me solve this? Thank you.
Regards,
Mircea
Extra question: How one can search for posts that have "loading…" string inside and avoid having listed all posts with "loading" only? Thank you!
Regards,
Mircea
