Using the Styles Editor
I added a NEW STYLE to the Styles Editor. I also gave the data of the weight per foot to the NEW STYLE.
I have several items that I have already created.
I want to assign the "new style" to these new items.
What is the next step?
Open up the part in which you created the new style, then find the style under MATERIAL in the left-side pane. Right click on the name, and select EXPORT. Then go to the part that you want it in, and use the IMPORT button. After it's imported, you'll still need to assign the material, though - it doesn't automatically assign it when you import.
Another step which is (short term) more complicated makes things simpler in the long run: create a basic template for your parts / assemblies / drawings, and import the styles you create to those. That way whenever you create a new part, your styles will come with it automatically.
