Hi,
When I open a new file in AutoCAD 2011 the size is 1:100 how can I change it to 1:1 ?
scaled.php?server=545&filename=cccok.png&res=medium
Thank you.
It's stored in the drawing, so if AutoCAD opens "Drawing1" at 1:100, it's because that's how it's set in your template.
Open the Template, change the scale, and re-save.
OK :thumbsup:
I created a template and changed in: Options ---> Files ---> Default Template File Name for QNEW
Thank you :)
Awesome. If this is your first template, you'll probably also want to add certain layers, text/dimension/multileader styles, linetypes, layouts, etc to that template so they're always immediately available whenever you start a fresh drawing.
You're speaking my language there nestly, no need to reinvent a finely tuned wheel ad nauseum. Table style is another good one to include.
