Before I begin, I have searched the web and the forums.
In a previous post I asked for help using a user defined variable to create layers. The help was quick and successful, I was able to complete a lisp that automates some of the work that I do. Thanks for the help.
I have decided to expand my lisp to include the ability to replace text on a layout with the user input.
I am looking for an example find and replace that will replace predefined text with the user input on a specific layout.
Example:
User input = 1
A layout is copied from an existing layout and named 1
I would like to replace all occurances of "AA" on layout 1 with 1 (User input)
Thanks
Here is a quick code not tested at all sorry
(defun C:FIR (/ elist en find replace sset txt)
 (if (not find)
   (setq find (getstring t "\nFind What? : "))
 (if (not replace)
   (setq replace (getstring t "\nReplace Whith? : "))
 (if (setq sset (ssget "_X" (list (cons 0 "text,mtext");<-- search for text and mtext
  ;(cons 410 (getvar "ctab");<-- search on current layout
     (cons 410 "1";<-- search on layout named "1"
   ;; iterating through selection set
(while
 ;; grab first entity from selection
 (setq en (ssname sset 0))
 ;; get entity list
 (setq elist (entget en))
 ;; get text string from entity list
 (setq txt (cdr (assoc 1  elist)))
 ;; check if this string is equal to what you look up
 (if (eq find txt)
     ;; substitute string with new value
     (setq elist (subst (cons 1 replace)(assoc 1 elist) elist))
     ;; modifies the definition data of an entity
(entmod elist)
 ;; remove first entity from selection to go to the next one within the loop
 (ssdel en sset)
(princ "\n\t   ---   Start command with FIR   ---")
~'J'~
