I want to draw reinforcement on inclined side but offset command is not working for reinforcement,How to draw equally spaced reinforcement on inclined side?
I tried geometric constraint but it also not working for circle.
retaining wall.dwg
Try rotating your crosshairs using the SNAPANG command. Please. Then you can use the ARRAY command.
Note: The center of your rebar is not located on the slanted line representing your vertical piece of rebar. Just thought you should know.
Suggestion: I would have either created a block for my rebar or used the DONUT command so the center of the bar could be picked/placed accurately.
There are several ways of getting to the same solution. I would use Measure with a block.
But using a Donut would be easier than using an area of solid hatch.
thanks eldon, but in donut command inner circle is hollow.
Will you please tell me how determine the angle of array for inclined surface.
The default is hollow but if you substitute 0.00 for the inside diameter it closes the hole. In other words, it is no longer a "donut".
Recreate your rebar as a block. Then use the MEASURE command as eldon instructed you to do. Please and thank you.
Does AutoCAD 2011 ARRAY command have a "Path" option? 2012 has it. Makes doing an array at something other than rectangular or circular pretty easy.
eldon I used donut but how to measure distance using block?
what to write in the name of block.
Block name = rebar sect or just plain rebar.
eldon has left the building. You're stuck with me. Lucky you.
Command: MEASURE
Select object to measure:
Specify length of segment or [block]: B
Enter name of block to insert: REBAR
Align block with object? [Yes/No] : Y
Specify length of segment: .4
no array path in 2011, but I did write a routine to do it for us....I also need rebar all over the place....
http://www.cadtutor.net/forum/showthread.php?64844-Array-along-arc-spline-pline-etc.&p=442778#post442778
additionally, attaced is one just for two point straight line arrays....
You don't have to make blocks for these either. Just pick drawing objects....or blocks if you wish.
hope it helps a bit.
ARRAY-2-PT.lsp
Thanks rickh for the info re: 2011 and the Array > Path option.
I'm sure others will benefit from your lisp routine but I'm not sure if the OP will be one of them at this time.
rickh
I didn't get single word from the file you have attached.All those I have to write in command pallet?
No. Use APPLOAD to load the lisp routine and use ARRAY2P to call the routine. It's right there in the code after defun c:
You did open the code right? Yes or No?
I only realized now that 'donut' is an actual AutoCad command, here I was all this time thinking people were just calling the rebar 'donuts' and that it must be an American thing lol.
That is a decent sized retaining wall.
Dink....I think you're just having some fun with us. Would you like a coffee and donut? LoL
