Openantics Posted February 23, 2012 Share Posted February 23, 2012 most often, our projects were built with the Imperial template. why does C3D assign points to a layer based on the marker type vs. what layer the user desires? For example, if I change the marker type to a benchmark symbol, the points get moved to a layer titled V-NODE-BENCHMARK regardless of the layer activated. More confusing, is the properties box shows the points listed in the layer that was active when they were created but not where they reside! The confusion (or understanding!) came when i wanted to hide those points for plotting. Is this just a function of the Imperial template? Quote Link to comment Share on other sites More sharing options...
