How do i draw a number (e.g. 3 ) 79mm high and 50mm wide with the character stroke of 14mm ??
Arcs that are eventually turned into polylines and given a width?
Find a suitable font, type the number 3 (at the desired height), explode it (using the Text Explode tool found in Express Tools) then edit to taste?
Type the # in a blank dwg. and save it.
Insert the #.dwg as a block into a new .dwg with set x and y scale for the block insertion.
Done.
I think the same could be done with an inserted xref?
BTW: What's a character stroke? and why is it so small with respect to the height/width of the character?
Cheers. If i have more problems i'll give u a shout.:)
@bill_borec These dimensions are for the UK number plate characters, whick im trying to write. But im finding it a bit difficult as i havnt used Cad in a long time, iv seemed to have forgotten most things :(
