Arrays with Lisp, that you can call back to...
I was wondering if someone would be able to help me with a program that will use unlimited lists that I can call back to the variables. For example... if I were to loop a question like "Is there a beam?" and also "Specify depth of beam?" - In which I could ask these questions, get input, run the sub routines then when it is all said and done I can go back to the 1st 2nd... nth inputs, so I could do more things later in the program. Hopefully this isn't too confusing.
Thanks,
sample code
(defun c:sample (/ doyourthing a b c)
(defun doyourthing (ls / pt)
      (princ (strcat "\nCurrent Beam size " "\t\t" (car ls)))
      (setq pt (getpoint "\nTesting purposes: Pick Point"))
      (command "_rectangle" "_non" pt "_non" (strcat "@" (itoa (cadr ls))
                                             "," (itoa (caddr ls))))
(setq marker (if (null marker) 0 marker))
     (while
           (initget  "Y L D")
           (setq a (getkword (if lst
                                 "\nCreate New List/\"L\" for Existing list [Yes/List/Done]?: "
                                 "\nCreate List  [Yes/Done]: ")))
           (if (eq a "D") nil T)
           (cond ((eq a "L")
                   (foreach itm (reverse lst)(print itm)(princ))
                   (setq b (getint "\nEnter List number: "))
                   (setq c (nth (1- b) (reverse lst)))
                   (doyourthing c)
                 ((eq a "Y")
                   (prompt "\nEnter Data:")
                   (setq b (getint "\nSpecify Depth of  Beam: "))
                       (setq c (getint "\nSpecify Heigth of  Beam: "))
                   (if (not (setq d (assoc (setq nm (strcat (itoa b) "X" (itoa c))) lst)))
                        (setq lst (cons (list nm b c (setq marker (1+ marker))) lst)
                                     c (car lst))
                               (princ "\Data Already Exist, using previous Data")
                               (setq c d))
                  (doyourthing c)
       );while (princ)
Command: sample
Create List [Yes/Done]: Y
Enter Data:
Specify Depth of Beam: 200
Specify Heigth of Beam: 300
Current Beam size 200X300
Testing purposes: Pick Point_rectangle
Specify first corner point or [Chamfer/Elevation/Fillet/Thickness/Width]: _non
Specify other corner point or [Area/Dimensions/Rotation]: @200,300
Command:
Create New List/"L" for Existing list [Yes/List/Done]?: Y
Enter Data:
Specify Depth of Beam: 100
Specify Heigth of Beam: 200
Current Beam size 100X200
Specify other corner point or [Area/Dimensions/Rotation]: @100,200
Command:
Create New List/"L" for Existing list [Yes/List/Done]?: L
("200X300" 200 300 1)
("100X200" 100 200 2)
Enter List number: 1
Command:
Create New List/"L" for Existing list [Yes/List/Done]?: D
HTH
Edited by pBe
add usage syntax/revrse list for viewing existing list
The other way would be to read and write a txt file with all the info per session or even reopen from last session went to lunch and want to continue.
Just a question what are you trying to produce is it steel connections etc
Thats a brilliant idea Bigal, that way the user can indeed use the list on another session. :thumbsup:
It is a brace frame automated program for my comany. The idea is for the user to type in gerneal info, and then wait and be done. I appriciate the work you did pBe, I may be able to utilize the one you had put on here but its not exactly what I was hopeing for. So... my problem is I want to be able to recall back to various amounts of user imputs that were taken from the questions answered. I talked to a programing buddy of mine that uses html and other softwares and he said that he would use an "Array", I'm not sure how exactly that translate into lisp.
For LISP, translating from other languages generally means
Array = List
Though, Visual LISP does offer a SafeArray data type.
Sorry if this is posting more than once, I think there is a problem on this end... I've heard of SafeArrays could you give some examples?
I could, but I don't think it would be necessary - you are far better off using a list for this task. LISP is built specifically for list processing and consequently is equipped with a multitude of list manipulation functions. SafeArrays are part of Visual LISP and only included for compatibility with ActiveX properties and methods; though if you specifically require some examples to learn about SafeArrays, the Visual LISP IDE (VLIDE) Help Documentation includes a lot of information on the subject.
Thanks Lee, Ill check in to that. I would like to learn the ActiveX method of programing sometime, I think it can help do things quicker.
