marchitect Posted February 28, 2012 Posted February 28, 2012 Hello, I use my own drawing templates with CUI files for layers, dims and notes to scale. Since I've been using LT2012, I've found that the CUI files don't appear in the drawing template. No problems re-loading them but I'd like them in the template if poss. Problem seems originate with LT2012 - didn't experience any difficulties with LT2011. Any suggestions? Quote
tzframpton Posted February 28, 2012 Posted February 28, 2012 CUI files don't have any connection with Templates. Are you referring to Workspaces by chance? Can you be a bit more clear about your issue? Quote
nestly Posted February 28, 2012 Posted February 28, 2012 My guess is that the term "CUI" was probably used improperly in this case, and marchitect wants 2012 to use the same drawing template as 2011 uses. If that's the case, just go to Tools > Options > Files > Template Settings, and use the "Browse" button to change the "Default filename for QNEW" to the same .dwt file as 2011 used. Quote
marchitect Posted February 29, 2012 Author Posted February 29, 2012 Hi Thanks for your reply - I had my own menus (text to scale etc) loaded into a drawing template but they didn't appear when I opened a drawing from the template. Now sorted tho. Thanks for your reply Quote
