Hi guys I can not sort this out, in paper space the blue lettering in the wc area shows up, but in paper space they do not, there is no layers turned off or funny colours problems as far as I can see, can anyone spot the probem please
I tried putting the blue lettering on to the remtex layer that shows up in paper space and still its the same ? :oops:
I can redo the lettering to get over the problem but I just need to know whats gone wrong with this layer please
test drawing.dwg
The text is set as Annotative. You can see it in Properites, change Annotative to No and you can see the text in paper space again.
Or do this ..... Enter new value for ANNOALLVISIBLE : 1.
Thanks guys that sorted it, any idea why the text was set to Annotative in the first place not had this problem before ?
Seems like an arbitrary decision, as there was also MTEXT which was not annotative. In drafting, as with so many other pursuits, there is much to be said for consistency. :)
