PDF in ACLT 2012 poor performance
I have put several drawings into the Publish> DWG>>> PDF mode.
The PDF comes out missing little bits of border lines around circles and elipses as well as some bleeding of colors.
Any suggestions?
Door and Chain 1-Model.pdf
The only missing lines I see are due to draw order issues, where the fill/hatch was printed after the border.
The only "Color bleeding" I see is from using gradient (shadowed) fill.
Are those huge black lines on the bottom of your 'door' supposed to be that thick?
It'd help if you could post the drawing so we could see how the layout is set up, and if you provided a description or example of the expected output.
Did you use the dwgtopdf.pc3 plotter or some third party pdf software?
I don't have the 2012 version of TrueView or AutoCad, so someone else will have to open the posted drawing and take a look at it.
