paisis123 Posted March 5, 2012 Posted March 5, 2012 As the title suggests, there is a block in my drawing that must be xploded. Its too big for AutoCAD to handle. Any tips/ tricks for this kind of conundrum!? those who help me get a virtual cookie. Quote
rkent Posted March 5, 2012 Posted March 5, 2012 Erase it, then use Insert, pick the Explode option (pick in box lower left), insert it. Quote
paisis123 Posted March 5, 2012 Author Posted March 5, 2012 (edited) Im confused on The "pick explode option", and insert it What do you mean by that? I should note that this block is a bunch of blocks within blocks. Edited March 5, 2012 by paisis123 added information Quote
rkent Posted March 5, 2012 Posted March 5, 2012 Use the LIST command to find the name of the block. Draw a circle at the insertion point of the block. Erase the block. Start the INSERT command. In the pull down select the block name of the super uber block. In the lower left pick in the box next to the work Explode. Pick the OK box to insert the block, .... Quote
paisis123 Posted March 5, 2012 Author Posted March 5, 2012 U got the Virtual COOKIE! It worked, i should of mentioned to u how BIG the file was......55,000 KB Quote
