myself Posted March 14, 2012 Posted March 14, 2012 I'm sure this has been talked here before, but i cant find that variable, option or whatever it is that controls if a layout appears according to the ctb selected or with the colors and configuration your using on your drawing. I mean, you have a drawing with many layers of different colors, if your layout is set to use "monochrome", you can only see it with white/black lines. I didnt dream, there's really an option to control this, i know there is Quote
DANIEL Posted March 14, 2012 Posted March 14, 2012 should be able to set the ctb through your page set up unless i'm misunderstanding you. Quote
rkent Posted March 14, 2012 Posted March 14, 2012 In the page setup there is a check off for display plot style, uncheck it. Upper right. Quote
Pablo Ferral Posted March 14, 2012 Posted March 14, 2012 How about this? http://www.ellenfinkelstein.com/acadblog/know-what-your-plot-will-look-like-when-you-use-plot-styles/ Quote
Dana W Posted March 14, 2012 Posted March 14, 2012 For Display, check or uncheck Display Plotstyles on your layout/page setup modify dialog. For plotting, check or uncheck Plot With Plotstyles on your layout/page setup modify dialog. Quote
