how do i get an image set in one coordinate system come into a drawing in another coordinate system?
You may try the "Copy with Base Point" option from Edit menu.
Regards,
Mircea
1) save the dwg with the image. then, insert the dwg as a block into the new coordinates.
OR
2) after saving the dwg...xref the dwg into a new file with the new coordinate system.
OR
3) CTRL-SHFT-C = Copy with Base Point
Welcome to the forum!
Thank you. I think I'm going to have to use the adequery command, though.
