Automatic Text Numbering V4, specific distance ( X or Y direction ) from cursor poin
As you well know, there are many options on the lisp mentioned above.
Lets assume you dont have the ATN V4 lisp nor Numinc.lsp What exactly do you want to do?
It means, for example I want to gove numbers just out of a circle
Are the text entity already exisitng? or are you creating a new one? textheight?
Are these Grid Number/Letter with increments
"A" "B" "C" --- > "Z" "AA" "BB"
or Labels?
"A1" "A2" "A3"
or Revision
"A" "B" "C" --- > "Z" "0" "1"
I will give distance for X and Y direction larger than the diameter of the circle so that when I click center of the circle, number will be placed just out of it as I wanted.
Why cant you just pick a point outside the circle?
  • Replies 25
  • ferhatpeker
    12
  • pBe
    9
  • fixo
    2
  • Lee Mac
    1
I think that if you look to my presentation, you will understand.
pres.pdf
Edited by ferhatpeker
You can still pick a point, really , and use that point as reference and pass it on on the next bllock, now question is does the text value increments with a fix value of + or - 1?
Before I do anything else, you have to remember we are not using the AutoNumber lsip code. we are making a simple code as possible as a separate routine, so dont assume all the options you had before will be incorporated on this one. Will that work for you?
OK.. (killing time)
Sample code
CODE REMOVED
Edited by pBe
Killing time
Dear pBe,
I used that lisp but this lisp not applicable for my work. I will do my work with autocad standard commands. Thanks for your help.
I will do my work with autocad standard commands......
:unsure: I could have sworn ATNV4 (LM) is a lisp code...
The posted code can be modified to select objects in the prefered sequence then specify the pick point on any of the block selected and the rest would follow.
Anyhoo.. your call.
Hi,
i tried this one,but its works up to few increments only
pls chk
