Dear all,
I'm quite new to LISP and I've been looking around the forum a lot for an answer to my problem but couldn't find it, therefore I ask your help!
I am trying to write a code that does these following actions:
1 - user types in command line (WOOD in this case)
2 - user selects an object (closed polyline or rectangle or whatever)
3 - lisp creates associative hatch with defined pattern and scale (var FILL and SC - since I want to do different materials with the same code, the pattern should be an independent variable) WITHOUT asking for internal point AND on the same layer as the selected object.
This is what I've done up to now but it asks for the internal point (actually if you select the internal point it won't hatch :?) and creates it in current layer...
(defun c:WOOD (/)
(setq FILL "ANSI31")
(setq cmdold (getvar "CMDECHO"))
(setq oldlayer (getvar "CLAYER"))
(setvar "CMDECHO" 0)
(setq SC "5")
(setq ent (entsel))
(command "._-bhatch" "_P" FILL SC "0.0" "_S" ent "")
(setvar "CMDECHO" 1)
(setvar "CLAYER" oldlayer)
Can anybody help me?
This ... ?
(defun c:Test (/ fill sc ss i sn)
 ;;; Tharwat 16. March. 2012 ;;;
 (setq fill "ANSI31"
       sc   5.
 (if (setq ss (ssget '((0 . "LWPOLYLINE,POLYLINE"))))
     (if (vlax-curve-isclosed (setq sn (ssname ss (setq i (1- i)))))
         (command "_.-hatch" "_P" fill sc "0.0" "_S" sn "" "")
         (entmod (subst (assoc 8 (entget sn))
                        (assoc 8 (entget (entlast)))
                        (entget (entlast))
Great! It works perfectly, thanks!
I had some problems at the beginning because I forgot to put in (vl-load-com), and I had to change to ._-bhatch otherwise it was giving an error...
You're welcome
