dsibbo Posted March 19, 2012 Share Posted March 19, 2012 I have a problem with a drawing when inserting a viewport. The drawing is from a client and on the model space the building appears to be in straight and looks correct. However when I go over to Pspace and insert a viewport the model is shown to be rotated at a crazy angle. Can anyone tell me how I can draw the viewport or change the setting so that it shows exactly how it is in model space. Thank you Quote Link to comment Share on other sites More sharing options...
Dadgad Posted March 19, 2012 Share Posted March 19, 2012 In your View Manager you can save the existing settings in the modelspace as a NAMED VIEW. In fact if you open your VIEW toolbar and check, you may find that a view has already been set up and saved. After you create your Viewport you can double click into it and set your view from the drop down view list. In order to change the view in a viewport it will need to be unlocked, and once you have set it how you want it, you should lock it so that it stays that way. Quote Link to comment Share on other sites More sharing options...
nestly Posted March 19, 2012 Share Posted March 19, 2012 My guess is that the UCS is twisted in modelspace to make the object appear "straight. Does the compass around the viewcube in ModelSpace line up with the "cube" or does it look like this Quote Link to comment Share on other sites More sharing options...
