einsuner12 Posted March 21, 2012 Posted March 21, 2012 Hi! I'm using W7 and ACAD 2010. I can't find my cui menu file. Thanks! M Quote
ReMark Posted March 21, 2012 Posted March 21, 2012 Look on your Ribbon. You want the "Manage" tab > Customization panel. Click on the icon for User Interface. You do know what you are doing right? Mistakes in editing the CUI can come back to haunt you. Quote
einsuner12 Posted March 21, 2012 Author Posted March 21, 2012 I want to make update to acad2010. They recommend to make backup of cui file. Quote
MSasu Posted March 21, 2012 Posted March 21, 2012 It is about acad.cui(x) or a custom one? Please take care that 2010 is using CUIX format. Some environment files were stored in Support folder under User profile and those folders are hidden by default. Try to paste this on your command prompt: (findfile "acad.cuix") Regards, Mircea Quote
ReMark Posted March 21, 2012 Posted March 21, 2012 When you install AutoCAD a backup copy of the original CUIx file is included. It is called acad.bak.cuix and can be found in the Support folder. Quote
