Hi,
Is it possible to assign an Atribute (or something similar) to an object like a Circle (without converting the circle to Block) for example? or link an object to an Atribute?
Thank you :)
Yes, with vanilla AutoCAD look at Xdata command from the express tools.
It would probably be easier to make the circle a block but set the attribute to invisible so it doesn't show.
Thank you for your help :)
It's OK ;)
