bikengineer Posted March 26, 2012 Posted March 26, 2012 I am trying to draw a bicycle frame in 3D. What is the best functions to use? I first drew the frame in 2D using regular lines. Next I drew a circle at one of the intersection points, then used Sweep. I repeated the steps but with a smaller circle. Next i was planning to Subtract the smaller tube with the large to create a tube but I am having trouble selecting to subtract to make a hollow tube. I'd like to revaluate to see if there is a easier way to draw so that it is easy to modify down the line. Quote
SLW210 Posted March 26, 2012 Posted March 26, 2012 Use _REGION on the two circles and _SUBTRACT prior to sweeping. Quote
rkent Posted March 26, 2012 Posted March 26, 2012 Solidedit > Shell will work and you don't have to draw the extra circle, extrude, etc. You can also draw a circle at the end of the tube and use PressPull to subtract. Quote
JD Mather Posted March 26, 2012 Posted March 26, 2012 Sweep of region is the far easier method - see http://home.pct.edu/~jmather/content/CAD238/AutoCAD%202007%20Tutorial%208.pdf Quote
rkent Posted March 27, 2012 Posted March 27, 2012 "Yeah, well, that's just, like, your opinion, man." The Dude Quote
JD Mather Posted March 27, 2012 Posted March 27, 2012 Not just opinion - it is fact. I assume the frame is more than one tube. I assume there might even be bent pieces. There might be multiple sizes (diameters) of tubes. Quote
