why dimension value doesn't change with scaling?
Your need to select the block and then you should see the blue triangle at the top of the block. see attached image.
  • Replies 20
  • khoshravan
    8
  • Bogbadbob658
    7
  • ReMark
    2
  • Dana W
    2
Posted Images
