ReMark Posted August 26, 2013 Share Posted August 26, 2013 Test it and find out. No time like the present. How long could it take you? Two minutes maybe (if that)? Quote Link to comment Share on other sites More sharing options...
PRA3889 Posted October 19, 2013 Share Posted October 19, 2013 but i am looking like this, i have attached a file please check Quote Link to comment Share on other sites More sharing options...
troggarf Posted October 19, 2013 Share Posted October 19, 2013 CAB wrote a versatile routine that will help with this instance. It has the option to break at the intersections and then delete every other segment. http://www.theswamp.org/index.php?topic=10370.0 This is a bundled function for Breaking Objects. After writing the BreakAll function the rest was easy. The following functions are a result. c:BreakAll - Break all objects selected c:BreakwObjects - Break many objects with a single object c:BreakObject - Break a single object with many objects c:BreakWith - Break selected objects with other selected objects c:BreakTouching - Break objects touching the single Break object c:BreakSelected - Break selected objects with any objects that touch it c:MyBreak - Dialog with buttons to run three of the routines c:BreakRemove - Break selected object with any objects that touch it & remove every other new segment, start with selected object Note: Color in picture not by lisp, but added for clairity. Quote Link to comment Share on other sites More sharing options...
rubyfire Posted September 11, 2016 Share Posted September 11, 2016 M.R.... This seems to be deleting or trimming anything outside the circle, not inside the circle? Quote Link to comment Share on other sites More sharing options...
BIGAL Posted September 12, 2016 Share Posted September 12, 2016 (edited) pra3389 Here is a version. ; assoc version (defun test ( / ss x c1) (setq ss (ssget (list (cons 0 "Circle")))) (repeat (setq x (sslength ss)) (setq c1 (entget (ssname ss (setq x (- x 1))))) (setq cenpt (assoc 10 c1)) (setq cenpt (list (nth 1 cenpt)(nth 2 cenpt) (nth 3 cenpt))) (command "trim" (cdr (assoc -1 c1)) "" cenpt "") ) ; repeat ) ;defun (test) ;vl version (defun test2 ( / ss x c1) (setq ss (ssget (list (cons 0 "Circle")))) (repeat (setq x (sslength ss)) (setq c1 (vlax-ename->vla-object (ssname ss (setq x (- x 1))))) (setq cenpt (vlax-safearray->list (vlax-variant-value (vla-get-center c1))) ) (command "trim" (vlax-vla-object->ename c1) "" cenpt "") ) ; repeat ) ;defun (test2) Edited September 12, 2016 by BIGAL Quote Link to comment Share on other sites More sharing options...
alanjt Posted September 12, 2016 Share Posted September 12, 2016 Oldie... (defun c:CIT (/ ss i e) ;; Trim Inside of selected Circles ;; Required subroutines: etrim (from Express Tool: EXTrim.LSP) ;; Alan J. Thomspon, 12.22.10 / 05.11.11 (if (or etrim (load "extrim.lsp" nil)) (if (setq ss (ssget '((0 . "CIRCLE")))) (repeat (setq i (sslength ss)) (etrim (setq e (ssname ss (setq i (1- i)))) (trans (cdr (assoc 10 (entget e))) 0 1)) ) ) (alert "Express Tool: EXTrim required!") ) (princ) ) Quote Link to comment Share on other sites More sharing options...
