Hello,
I have created this little lisp for drawing two arcs in the "young moon" shape inside picked circle. Now I need your help to teach me how to hatch or solid fill that area ... :?
(defun c:test ()
;get info of circle
(setq circleObj (car(entsel "\nSelect circle :")))    ;Get ename of circle object picked
(setq e_circleObj (entget circleObj))        ;Get record of Entity Circle
(setq cp (cdr (assoc 10 e_circleObj)))        ;Get Center Point by dxf 10
(setq r (cdr (assoc 40 e_circleObj)))        ;Get Radius by dxf 40
;Calculation
(setq a1 (* 2 (/ r 10)))
(setq r1 (- r a1))
(setq r2 (sqrt (+ (expt a1 2) (expt r1 2))))
(setq alfa1 (- (* 2 pi) (atan (/ r1 a1))))
(setq alfa2 (atan (/ r1 a1)))
;Draw
;Arc 1
    (entmakex
     (list (cons 0 "ARC")
      (cons 10  cp)
      (cons 40  r1)
      (cons 50 (* 3 (/ pi 2)))
      (cons 51 (/ pi 2))
     );end list
    );end entmakex
   )end progn
;Arc 2
    (entmakex
      (cons 10  (polar cp pi a1))
      (cons 40  r2)
      (cons 50 alfa1)
      (cons 51 alfa2)
     );end list
    );end entmakex
   )end progn
) ;end defun
Thank you very much for you help.
You may create a polyline from those arcs and call HATCH command on it:
(command "_PEDIT" entityArc1st "" "_J" entityArc2nd ""
        "_HATCH" "_P" "SOLID" "_S" (entlast) "" "")
Regards,
Mircea
Thank you Miricea for your reply. :)
I also like your approach (I was thinking the same), but I dont know how to "call" arcs after pedit command to join them .... I tried to put your code after defining second arc and I got some error messages ....
Maybe you think I should (not) do that :ouch:
The ENTMAKEX function will return the name of the entity:
[color=red];    (progn[/color]
[color=blue]    (setq entityArc1st[/color]
     (entmakex
       (cons 10  cp)
       (cons 40  r1)
       (cons 51 (/ pi 2))
      );end list
     );end entmakex
[color=blue]    )[/color]
[color=red];    )end progn[/color]
Also, there is no need for those PROGN.
Regards,
Mircea
Thank you again Mircea for help and lesson :).
You're welcome!
So, did you manage to finnish your routine?
Regards,
Mircea
Yes Mircea, with your great help I manage to finish this routine, and now it looks like this:
(defun c:test ()
;get info of circle
;Calculation
(setq r1 (- r a1))
;Draw
;Arc 1
   (setq entityArc1st
    (entmakex
      (cons 10  cp)
      (cons 40  r1)
      (cons 51 (/ pi 2))
     );end list
    );end entmakex
   );end setq
;Arc 2
   (setq entityArc2nd
    (entmakex
      (cons 40  r2)
      (cons 50 alfa1)
      (cons 51 alfa2)
     );end list
    );end entmakex
   );end setq
;Draw poly
(command "_PEDIT" entityArc1st "" "J" entityArc2nd "" ""
        "_HATCH" "SOLID" "_S" (entlast) "" )
) ;end defun
Again thank you very much you taught me a lot :).
