Hi
I'd like to draw an half eliptic cylinder with its base on a yz plan ... but I don't find the tool to change from xy to another plan.
Thanks for your tips :)
Why not just draw it and use rotate3d and rotate it to the orientaion you like?
It looks to work ... the time to understand the logic :)
Many thanks JD Mather
I'll check rotate3d ... it may will be easier.
Thanks to both of you
