Retrieving the block name once in block editor
I'm making a lisp to use inside the blockeditor. I have not figured out how to get the block name without having to type it in.. How do I go about achieving this?
Seems that there is no system variable to store that (for REFEDIT command you have REFEDITNAME).
One solution will be to try to redefine the BEDIT command to get control over user's selection.
Regards,
Mircea
I guess it would depend how you invoke the BEDIT command:
(defun c:BedName ()
(setq bn (ssget "_:S:E:L" '((0 . "INSERT"))))
(setq bnm (cdr (assoc 2 (entget (ssname bn 0)))))
(sssetfirst nil bn)
(command "_bedit")
(defun otherFun (b)
     (princ (strcat "\nCurrent Blockname " b":"))
     (setq pt (getpoint "\nPick point:")))
(otherfun bnm);
  • 2 weeks later...
I don't like it, but it works
(defun c:test ( / l1 p l2 r )
 (vl-load-com)
 (if (eq 1 (getvar 'blockeditor))
     (vlax-for x
       (vla-get-blocks
         (setq *acdoc*
           (cond  ( *acdoc* )
             ( (vlax-get (vlax-get-acad-object)
                 'ActiveDocument)
       )(setq l1 (cons (cons (vla-get-count x) x) l1))
     (setq p
       (entmakex
         (list (cons 0 "point")
           (cons 10 '(0. 0. 0.))
     ) (vl-cmdf "_.bsave")(entdel p)
     (vlax-for x (vla-get-blocks *acdoc*)
       (if
         (not
           (or
             (vl-position
               l1
             (eq "*MODEL_SPACE"
               (vla-get-name x)
         )(setq l2 (cons x l2))
     ) (alert (vla-get-name (car l2)))
     (vl-cmdf "_.bsave")
   ) (prompt "\nCommand only allowed in block editor!!")
 ) (princ)
