I cobbled together this lisp years ago to essentially offset just a part of a line and would like to make it better.
The error trap doesn't seem to work.
I would like to have it change to a layer of the object picked, or maybe another layer to be specified later.
I imagine it can be cleaned up but I am not sure where to focus first.
;OffsetMeasure  offset a short line
(defun *error* (msg)
 (setvar "osmode" 0)
   (setq pt1 nil)
   (setq pt2 nil)
   (setq dist1 nil)
   (setq *seqpt nil)
 (princ "\n\n\nLeaving OM lisp routine, good day sir!\n")
(defun C:OM (/ pt1 pt2 dist1 srt)
 (setvar "cmdecho" 0)
 (setq srt (getvar "sortents"))
 (setvar "sortents" 3)
 (graphscr)
 (setq d "T")
   (while d
     (if (not *seqpt)(setq *seqpt 1.0))
     (princ "\nEnter Distance For Offset <")
     (princ *seqpt)
     (setq dist1 (getdist ">: ")
 (setvar "osmode" 512)
   (setq pt1 (getpoint "\nPick point on object :")
         pt2 (getpoint "\nSecond point :")
   (if (not dist1)(setq dist1 *seqpt)(setq *seqpt dist1)
 (setvar "osmode" 0)
 (command ".line" pt1 pt2 "")
   (princ "\nSide to offset")
 (command ".offset" dist1 pt1 pause ""
           ".erase" pt1 ""
           ".move" pt1 "" "@" "@")
  (setq d1 (strcase (getstring "\nPress RETURN to continue or X to
quit ")))
  (if (= d1 "X")(setq d nil))
  (setvar "sortents" srt)
Any help would be appreciated. Point me in a direction or do it all for me, I don't have a preference.:D
rkent
Having only skimmed your code, consider nesting the temporary *error* defun within the main code (c:OM), and be sure to localize the symbol so that once the main code completes the original *error* definition is restored. Pseudo code:
(defun c:OM ( / *error* ;|Other vars|
   ;; <-- Your error handler here
 ;; <-- Main code here
Renderman, that worked! Thanks, rkent
@ Rkent - Happy to help. :)
@ Lee - Well written tutorial, my friend. :beer:
