asos2000 Posted October 28, 2008 Share Posted October 28, 2008 I made DB with arrayed object, How do I know how many time that object repeated? Quote Link to comment Share on other sites More sharing options...
dbroada Posted October 28, 2008 Share Posted October 28, 2008 I have an attribute in my DBs with a formula field. The fomula is Distance(parameter)/width (of array). There are a couple of problems with this though. If you type anything in the attribute field the link gets broken - even typing in the original formula. This is eased by setting ATTREQ = 0 to stop the dialogue box appearing on insertion of the block. The field only gets updated with a regen. Simple to cure but can catch you out if you're not ready for it. Check my attached file as its easier to observe than explain. TerminalGroup-SAKR.dwg Quote Link to comment Share on other sites More sharing options...
asos2000 Posted October 28, 2008 Author Share Posted October 28, 2008 A temper solution I did drawn a line Length= 1 creat strech action chained to th array action and the Distance maltiplier = 1/the arryed distance Quote Link to comment Share on other sites More sharing options...
dbroada Posted October 28, 2008 Share Posted October 28, 2008 on mine I use the distance control as the base and array from that. Quote Link to comment Share on other sites More sharing options...
asos2000 Posted October 29, 2008 Author Share Posted October 29, 2008 Look at that solution but the formula at second line doesnt work Regards Test-04.dwg Quote Link to comment Share on other sites More sharing options...
asos2000 Posted November 2, 2008 Author Share Posted November 2, 2008 Is there no solution? Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 2, 2008 Share Posted November 2, 2008 doesn't my way work for you? I don't have AutoCAD here so can't look at yours. Quote Link to comment Share on other sites More sharing options...
asos2000 Posted November 3, 2008 Author Share Posted November 3, 2008 I am asking for more when makking array what is the balance? Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 3, 2008 Share Posted November 3, 2008 I'm now able to look at your block but I'm not sure what you are doing. Can you explain it a bit please. Also you have a few yellow exclaimation marks in the editor - this means that you have put a parameter in place but haven't assigned an action to it. Quote Link to comment Share on other sites More sharing options...
asos2000 Posted November 3, 2008 Author Share Posted November 3, 2008 at first thanx for your attention - For the yellow exclaimation marks, I added a dummy Parameters to get some length whech we using in laoding design - For the lenght What i want, I am doing a that DB the draw a panel width is 1200mm the height is varies I made the array and strech all is ok what im asking about is, suppose I srtreched that DB 4500 it means there are 3 panels equals and one panel 900 mm Is there a way to get the palance? Regards Quote Link to comment Share on other sites More sharing options...
dbroada Posted November 4, 2008 Share Posted November 4, 2008 I can now see your problem but I can't see a solution. Ideally we need to use an integer function in the formula as all we want is remainder = length - 1200 * INT(length/1200) but I can't get INT to work. I have tried a few ways to try and leave a dimension that can be measured but can't get it to work. Quote Link to comment Share on other sites More sharing options...
