ATS1211 Posted April 17, 2012 Posted April 17, 2012 Hello all, I am somewhat familiar with AutoCAD and LISP but I was just presented with a problem and I have no idea how to begin to attack it. I have a series of 500+ DWG's that all contain .bmp images as xref's; however, I need to update the file extension to ".ecw" since the file size is drastically smaller (I have the images in both file types but at the time .bmp's were the only ones available). So, I know I can create a selection set of all the images in the drawing, but I cannot figure out how to change the extension or where I even need to look for the "type". Any help is appreciated! Quote
MSasu Posted April 17, 2012 Posted April 17, 2012 Should look for DXF code 1: (entget (cdr (assoc 340 (entget (car (entsel)))))) Quote
BIGAL Posted April 18, 2012 Posted April 18, 2012 1st Have the bmp's been scaled and are the ecw the same size ? 2nd lisp to make list of the xref names and insert pt then delete bmp xref then xref in new ecw at old pt hint use dotted pairs (name . x,y) maybe also xrefmanager Quote
MSasu Posted April 18, 2012 Posted April 18, 2012 There is no need to delete the BMP reference, is just enough to replace file's path: (setq assocImage (entget (cdr (assoc 340 theImageEntity)))) (setq pathOld (cdr (assoc 1 assocImage)) pathNew (strcat (substr pathOld 1 (- (strlen pathOld) 3)) "ECW")) (entmod (setq assocImage (subst (cons 1 pathNew) (assoc 1 assocImage) assocImage))) Quote
