I urgently needed a lisp routine that performs the following:
I have many closed polylines, each one with an name.
I needed a lisp routine that asks the name of this area and quickly runs a "Zoom To" for that area. Like a Zoom extends on the polyline limits.
Someone could help me? Thank you. :(
I think you will search for the location of a polyline by the text string only and not by Polylines . right ?
I want to identify the text within an area bounded by a closed polyline and zoom extend this same area. :????.
Greetings.
Hope this helps get you started..
(defun c:test ( / p )
 (if
   (and (setq p (car (entsel "\nSpecify polyline: ")))
     (eq "LWPOLYLINE" (cdr (assoc 0 (entget p))))
     (setq p (vlax-ename->vla-object p))
   (apply (function vla-zoomwindow)
     (cons (vlax-get-acad-object)
         (lambda ( / ll ur )
           (vla-getboundingbox p
             'll 'ur
           ) (list ll ur)
 )(princ)
Maybe try something like this:
[color=GREEN];; Zoom to Polyline  -  Lee Mac 2012[/color]
[color=GREEN];; Prompts for the 'name' of a Polyline, that is, the contents of text[/color]
[color=GREEN];; residing within the Polyline Boundary, and zooms to the Polyline.[/color]
([color=BLUE]defun[/color] c:zoomto ( [color=BLUE]/[/color] cmd ent pt1 pt2 sel str )
   ([color=BLUE]while[/color]
       ([color=BLUE]not[/color]
           ([color=BLUE]or[/color] ([color=BLUE]zerop[/color] ([color=BLUE]strlen[/color] ([color=BLUE]setq[/color] str ([color=BLUE]getstring[/color] [color=BLUE]t[/color] [color=MAROON]"\nSpecify Polyline Name: "[/color]))))
               ([color=BLUE]setq[/color] sel
                   ([color=BLUE]ssget[/color] [color=MAROON]"_X"[/color]
                       ([color=BLUE]list[/color] '(0 . [color=MAROON]"TEXT,MTEXT"[/color])
                           ([color=BLUE]cons[/color] 1
                               ([color=BLUE]vl-list->string[/color]
                                   ([color=BLUE]apply[/color] '[color=BLUE]append[/color]
                                       ([color=BLUE]mapcar[/color]
                                           ([color=BLUE]function[/color]
                                               ([color=BLUE]lambda[/color] ( a b )
                                                   ([color=BLUE]cond[/color]
                                                       (   ([color=BLUE]member[/color] a '(35 64 46 42 63 126 91 93 45 44))
                                                           ([color=BLUE]list[/color] 96 a)
                                                       (   ([color=BLUE]<[/color] 47 a 58)
                                                           ([color=BLUE]list[/color] a)
                                                       (   ([color=BLUE]list[/color] 91 a b 93))
                                           ([color=BLUE]vl-string->list[/color] ([color=BLUE]strcase[/color] str))
                                           ([color=BLUE]vl-string->list[/color] ([color=BLUE]strcase[/color] str [color=BLUE]t[/color]))
       ([color=BLUE]princ[/color] [color=MAROON]"\nPolyline not found."[/color])
   ([color=BLUE]if[/color] sel
       ([color=BLUE]progn[/color]
           ([color=BLUE]setq[/color] cmd ([color=BLUE]getvar[/color] 'cmdecho)
                 ent ([color=BLUE]entlast[/color])
           ([color=BLUE]setvar[/color] 'cmdecho 0)
           ([color=BLUE]vl-catch-all-apply[/color]
              '([color=BLUE]lambda[/color] [color=BLUE]nil[/color]
                   ([color=BLUE]vl-cmdf[/color] [color=MAROON]"_.-boundary"[/color] [color=MAROON]"_A"[/color] [color=MAROON]"_I"[/color] [color=MAROON]"_N"[/color] [color=MAROON]""[/color] [color=MAROON]"_O"[/color] [color=MAROON]"_P"[/color] [color=MAROON]""[/color] [color=MAROON]"_non"[/color]
                       ([color=BLUE]trans[/color] ([color=BLUE]cdr[/color] ([color=BLUE]assoc[/color] 10 ([color=BLUE]entget[/color] ([color=BLUE]ssname[/color] sel 0)))) 0 1) [color=MAROON]""[/color]
           ([color=BLUE]setvar[/color] 'cmdecho cmd)
           ([color=BLUE]if[/color] ([color=BLUE]equal[/color] ent ([color=BLUE]setq[/color] ent ([color=BLUE]entlast[/color])))
               ([color=BLUE]princ[/color] [color=MAROON]"\nUnable to Zoom to Polyline."[/color])
                   ([color=BLUE]vla-getboundingbox[/color] ([color=BLUE]vlax-ename->vla-object[/color] ent) 'pt1 'pt2)
                   ([color=BLUE]vla-zoomwindow[/color] ([color=BLUE]vlax-get-acad-object[/color]) pt1 pt2)
                   ([color=BLUE]entdel[/color] ent)
   ([color=BLUE]princ[/color])
([color=BLUE]vl-load-com[/color]) ([color=BLUE]princ[/color])
You are extraordinary. Thank you both.
Best regards.
....(<  47 a 58)
I didnt know "
(vl-list->string
           (apply 'append
               (mapcar
                   (vl-string->list (strcase str))
                   (vl-string->list (strcase str t))
Clever utilizing range for a non case sensitive selection. Never cease to amaze me my friend :thumbsup:
Edited by pBe
A term used in my country: Many years to turn the steaks on the grill.
Congratulations, LeeMac.
I think it still working without check condition number, Wildcard...
Sth like this :
[color=#000000][color=#007700]([/color][color=#0000BB]vl[/color][color=#007700]-list->[/color][color=#0000BB]string
   [/color][color=#007700]([/color][color=#0000BB]apply [/color][color=#DD0000]'append
       (mapcar  '[/color][color=#007700]([/color][color=#0000BB]lambda [/color][color=#007700]( [/color][color=#0000BB]a b [/color][color=#007700])(list [/color][color=#0000BB]91 a b 93[/color][color=#007700]))
           ([/color][color=#0000BB]vl[/color][color=#007700]-[/color][color=#0000BB]string[/color][color=#007700]->[/color][color=#0000BB]list [/color][color=#007700]([/color][color=#0000BB]xstrcase str[/color][color=#007700]))
           ([/color][color=#0000BB]vl[/color][color=#007700]-[/color][color=#0000BB]string[/color][color=#007700]->[/color][color=#0000BB]list [/color][color=#007700]([/color][color=#0000BB]strcase str t[/color][color=#007700]))
) [/color][/color]
Sth like this :
Consider the case in which the name contains wildcard operators, e.g. "a*b" ;)
Concerning the numbers, I saw no reason to duplicate them in the wildcard filter...
That right Lee. I just found that it still work even we want to find str "a*b" (with * is a normal character) , it means "[**]" = "'*" in ssget filter.
I think it's 6 of one and half a dozen of the other, but personally, I think:
"[Aa]`*[bb]"
is more readable than:
"[Aa][**][bb]"
Lee, this code is very good and I'm trying to understand line by line all the steps. I would like to learn autolisp with all yours cooperation, and I believe it is a good way to learn.
Taking this same code, and according to the attached file that we have areas that begin with "AA", "AB" and "AC", how would the code be changed so that it was possible to make a ZoomTo, for example, all names areas starting with "AB"?
Best regards.
Example2.dwg
