fixo Posted April 27, 2012 Posted April 27, 2012 (edited) Try add: (vl-load-com) before of routine... (defun c:tocsv(/ file lst data datum dia ent1 ent2 ent3 leng pos) [color=red](vl-load-com)[/color] ;;list to file (defun wrs (file lst / filename atts blockname en obj ss) (setq filename (open file "W")) (foreach x lst (write-line x filename) ) (close filename) (princ) ) (setq file (strcat (getvar "dwgprefix")(vl-filename-base (getvar "dwgname"))".csv"));<-- or change file name here (setq data (list (strcat "pos no" "\t" "pipe diameter" "\t" "pipe length (m)"))) (while ;(setq ent (entsel"\nSelect block: ")) (setq ss (ssget "_:S" (list (cons 0 "insert")(cons 2 "YAZI KANAL")))) (setq blkobj (vlax-ename->vla-object (ssname ss 0))) (foreach att (vlax-invoke blkobj 'getattributes) (cond ((eq (vla-get-tagstring att)"A")(setq aa (vla-get-textstring att))) ((eq (vla-get-tagstring att)"B")(setq ba (vla-get-textstring att))) ((eq (vla-get-tagstring att)"DEBI")(setq da (vla-get-textstring att)))) (setq tmp (strcat (vl-princ-to-string aa) "\t" (vl-princ-to-string ba) "\t"(vl-princ-to-string da))) ) (setq data (cons tmp data))) (setq data (reverse data)) (wrs file data) (princ) ) (princ "Start command with: TOCSV") (prin1) But it sounds ugly, it does work on my machine, thus I can't help with other questions, bye ~'J'~ Edited April 27, 2012 by fixo Quote
