Hi, i want to print the following lines in an opened text file:
num01 num02 string03
-4.344 -3.842 string_val1
4.358 -3.820 string_val2
-0.130 -3.842 string_val3
i use (princ (...) file) and (princ "\t\t" file) two taps between every two strings. because of the different length of the data, the data are not aligned to the respective column, such that every column is aligned with "num01", "num02" or "string03". is there a way to go around with this?
Thx in advance.
Try these functions:
(defun wrs (file lst / filename )
(setq filename (open file "W"))
(foreach x lst
(write-line (lst2str x "\t") filename)
(close filename)
(defun lst2str (lst sep)
(if (cadr lst)
(strcat (vl-princ-to-string (car lst))
sep
(lst2str (cdr lst) sep)
(setq lst (list (list "num01" "num02" "string03")
(list "-4.344" "-3.842" "string_val1" )
(list "4.358" "-3.820" "string_val2" )
(list "-0.130" "-3.842" "string_val3")))
;;Usage:
(wrs "C:\\Test\\ahhah.csv" lst);<--- change file name to suit
~'J'~
[/b][/color]
EDIT: :shock: My bad. i thought its the other way around [retarded ]
Edited by pBe
(foreach x lst
(close filename)
(if (cadr lst)
sep
;;Usage:
~'J'~
hi fixo, i tried the function but i stll got the same...
Thx for the help any way... and this is wat i see in wordpad:
Would you setlle for " " instead of tab? or you really want tabs?
Do you have a routine for converting teh test string to a list?
For space " " not tab "\t" and .txt format
(defun _strnum  (val tl / p)
     (repeat (- tl (strlen val))
           (setq p (strcat " "
                           (if p p " "))))
 (strcat val p))
List after parsing
(setq lst '(("num01" "num02" "string03")("-4.344" "-3.842" "string_val1")
    ("4.358" "-3.820" "string_val2" )("-0.130" "-3.842" "string_val3")))
The code
(foreach itm lst
 (write-line (strcat  (_strnum (car itm) 12)(_strnum (cadr itm) 12)
  (last itm)) filename)
It would look like this
We can also make one for tabs if thats what you require.
For Tabs:
(setq _HiLo (lambda  (lst mode p)
 (+ (apply mode
 (mapcar '(lambda (j)
     (strlen (p j))) lst)) 2)
(setq fval (_HiLo lst 'Max car)
     Sval  (_HiLo lst 'Max cadr))
(foreach itm lst
 (write-line (strcat  (_strnum (car itm) fval)"\t"(_strnum (cadr itm) Sval) "\t"
HTH
Edited by pBe
hi pBe, i think i would settle for the space one... ""
it works finely... thank u very much for the help
You're Welcome Joedevil. Glad to help
You can adjust the number of space " " here --> (_strnum (car itm) 12), that is total lenght of string per column except the last. as for importing it back to cad, that will require another routine to consider those whitespaces , but its fairly easy. Holler if you need a code for that too.
Cheers :)
Joedevil, it will be interesting also to clarify which are your goals with this file and his aligned data.
If is about a report that is to be printed, then pBe’s solution with spaces is the most suitable since using may conduct to misalignments in some cases.
If the file is a database that would be accessed later to read his content, a one character separator (, "," or ";") is a much effective solution.
