I am enrolled in an AutoCAD Architecture Design class.
The assignment is to draw a residential stairway, which is not a problem. I have the stairway elevation and plan views drawn. All the code requirements listed. What I meed some ideas for stairs rail design.
these are some of the instructions. Guardrail may be of any material or configuration allowed by code; the focus of the project is the design of the guardrail.
Floor to floor height is 12ft 2in. I was thinking of a vine or grape vine motif. Anyone have any other suggestions.
I am a steel detailer and working on some railings right now. I have been doing these for about 30 years.
The current rail I'm working on has:
Top Rail = Tube 2" O.D. x .125 wall (Set at +3'-7")
Intermediate Rails = 3/16" dia Uncoated 1X19 Stainless Steel Cables
End posts = BAR 2 x 2
Intermediate posts = BAR 2 x 1
Grabrail = Tube 1-1/2" O.D. x .125 wall (Set at +2'-11")
Grabrail support elbows = 5/8" dia rods
There are many simpler ones. I could send a pdf.
Jeff
Google ornamental or architectural railings and I suspect you will find plenty, or use COOLIRIS if you have that, as it is a really nice way to view lots of images side by side.
Thanks Dadgsd, I will use those key words.
I don't have COOLIRIS.
You're very welcome.
I believe that you can download cooliris as an add-on to firefox. I just googled both of those searches, no shortage of good ideas!
ACA has preinstalled existing railing styles in the default directory. Check out in Options where the styles are.
