Is there a way to make sure whenever I x-ref a file it is not saved as "full path"? I prefer that be the default as I never x-ref outside of the folder I am working in.
Thanks!
That option is saved in Windows Registry, so should be preserved between sessions.
I'm afraid that, since you are using LT, the option to use a start-up AutoLISP routine to fix this automatically isn't available.
