ChloeG Posted October 29, 2008 Share Posted October 29, 2008 There's a tool called '3D Solid' on autocad architecture, but since i only have autocad on this laptop, i cant seem to find it when i right click on the toolbars. How can i find it?Cheers you guys Quote Link to comment Share on other sites More sharing options...
manhattan Posted October 29, 2008 Share Posted October 29, 2008 Theres should be a toolbar called modeling(depending on your versions of cad) which contains buttons for 3d solid primitives and a few editing commands EDIT: you could also load the 3d workspace which should contain pretty much every tool you need for a bit of modeling. beware though, if you have your workspace setup just how you like it be sure to save it before changing, otherwise when you switch back again it'll change to default Quote Link to comment Share on other sites More sharing options...
GhostRider Posted October 29, 2008 Share Posted October 29, 2008 The modeling toolbar is the same I believe Quote Link to comment Share on other sites More sharing options...
ChloeG Posted October 29, 2008 Author Share Posted October 29, 2008 Yay! It is the same. Cheers guys Quote Link to comment Share on other sites More sharing options...
