nathanaelbfw
UCS lisp routines?
nathanaelbfw
Hi all!
I have been learning lisp routines and am struggling to work out the one I need to rotate my model space.
I have solved the routine for getting back to the original ucs setting:
(defun c:EU nil (command "ucs" "w" "plan" "w") (princ))
The one that isn't working I think should look like this:
(defun c:UE nil (command "ucs" "e" "plan" "current") (princ))
However, this routine fails to rotate to the current UCS despite registering the selected ucs.
Thank you
Share this post
Link to post
David Bethel
UCS _E is looking for an entity to align with.
The first one is pretty straight forward.
I can't tell exactly what you are trying to with this one. -David
Share this post
Link to post
Lee Mac
A guess:
(defun c:ue nil (command "_.ucs" "_OB" pause "_.plan" "_C") (princ))
Share this post
Link to post
nathanaelbfw
Must be why I found it so easy...
what I am trying to work out is how to write a routine to shorten what I would normally do.
my normal approach would be:
UCS
E
select the line
Plan
Current.
I hope this hasn't made it more confusing.
Share this post
Link to post
nathanaelbfw
Thank you.
I supposed my next question is more complicated.
How do I save these lisp routines so that I don't have to load them each time I open a new window?
Share this post
Link to post
MSasu
Please check this tutorial from Lee Mac's website.
To call the routine in code:
(c:EU)
Share this post
Link to post
