All,
I am facing issue with LISP code which runs fine with ACAD 2005. LISP stmt is (command "trim" e1 "" p30 "")
If i run same code on ACAD 2010 then while selecting objects for trimming if ACAD couldn't find objects at specified point (p30) then it will start forming a window and will stuck there since opposite corner is not specified.
We have used trim at multiple places in overall code.
I tried with PICKAUTO abd PICKADD variable but still while selecting object to trim it will form a crossing window.
Is there any other method thru which I can avoid this crossing window?
Regards,
Kaustubh
Try
(if (nentselp p30) (command "trim" e1 "" p30 ""))
