ARRAYPOLAR command's input of item malfunction (AutoCAD 2012)
Have tried the ARRAYPOLAR command on AutoCAD 2012 and seems that there is a problem with the prompter asking for number of items. It seems to randomly accept or reject the numerical keyboard input:
Command: ARRAYPOLAR
Select objects: 1 found
Select objects:
Type = Polar Associative = Yes
Specify center point of array or [base point/Axis of rotation]:
Enter number of items or [Angle between/Expression] : 10
Specify the angle to fill (+=ccw, -=cw) or [EXpression] :
Command: ARRAYPOLAR
Select objects:
Point or option keyword required.
Enter number of items or [Angle between/Expression] : 11
I'm doing something wrong or miss something? Also, seems that I'm not the only one affected.
Mircea, does seem a bit random, try selecting a basepoint and I think you will find it will work better. :)
Thank you for suggested workaround, Dadgad!
Indicating the basepoint seems to solve the issue when command is used on prompter, but unfortunately when called through AutoLISP the error is still there at each try.
Use the ARRAY command in your LISP program. You can test it on the command line by typing -ARRAY.
