dirtlegg Posted May 17, 2012 Share Posted May 17, 2012 I have created a surface from contours for a tank containment area. I need the volume up to a certain elevation. The results i am getting have some fill volume and some cut volume...how can this be???? Autocad 2002 today. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2012 Share Posted May 17, 2012 How are you obtaining the volume? Can you post a copy of the drawing with just the containment area? Quote Link to comment Share on other sites More sharing options...
dirtlegg Posted May 17, 2012 Author Share Posted May 17, 2012 working on a different computer...had to do this in 2002 with eaglepoint. i have done this before with good results...but now i get a cut and a fill?? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2012 Share Posted May 17, 2012 See my revised reply. OK....so you are using an add-on program. Gotcha. Quote Link to comment Share on other sites More sharing options...
dirtlegg Posted May 17, 2012 Author Share Posted May 17, 2012 ok...how do i create a surface from contours in 2012?? Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2012 Share Posted May 17, 2012 (edited) How about just posting what you got instead of recreating the wheel? Personally, I might have gone with lofting the contours and creating solids but I am in no position to say whether or not that idea is any better than yours. Heck, I thought YOU were the expert here not me. LoL A tank containment area. You must have created a berm right? Is the site fairly level? I suppose, without seeing what you have to work with, I would have drawn the centerline of the containment berm and a profile of the berm itself. I would have used the Sweep command and swept this profile along the path represented by the centerline. With not much effort I could have obtained the shape and volume of the contained area. Edited May 17, 2012 by ReMark Quote Link to comment Share on other sites More sharing options...
JD Mather Posted May 17, 2012 Share Posted May 17, 2012 ok...how do i create a surface from contours in 2012?? Loft an slice http://home.pct.edu/~jmather/AU2007/GD211-2P%20Mather.pdf pg11 keep the loft profiles simple. Quote Link to comment Share on other sites More sharing options...
ReMark Posted May 17, 2012 Share Posted May 17, 2012 My containment berm created as a solid (brown). The interior volume depicted in greenish color. Having a copy of your drawing would be a big help to us. Quote Link to comment Share on other sites More sharing options...
