MikeP Posted May 18, 2012 Posted May 18, 2012 Its functioning correctly, but Im getting an error in the end it. Porque? (defun c:ppb (/ ss1) (setq ss1 (ssget )) (command "_.change" ss1 "" "P" "color" "magenta" "") (command "copyclip" ss1 "") (command "_.change" ss1 "" "P" "color" "Green" "") (command "pasteblock" ss1) (princ) ) Quote
MikeP Posted May 18, 2012 Author Posted May 18, 2012 (command "pasteblock" pause) Thanks it work, but now it shows all this in the command line: Command: pasteblock Duplicate definition of block _ARCHTICK ignored. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHTITL.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [ARCHITXT.shx]. Substituting [simplex.shx] for [arch]. Substituting [simplex.shx] for [Arial Black]. Substituting [simplex.shx] for [Tahoma]. Substituting [simplex.shx] for [archstyl.shx]. Substituting [simplex.shx] for [3 of 9 Barcode]. Substituting [simplex.shx] for [C:\Program Files\AutoCAD LT\Archstyl.shx]. Quote
MikeP Posted May 18, 2012 Author Posted May 18, 2012 and can you please explain the function/purpose of the "pause"? Quote
pBe Posted May 18, 2012 Posted May 18, 2012 It lietrally means "Pause for User Input" , Like your inside the command,(simple like that Quote
Lee Mac Posted May 18, 2012 Posted May 18, 2012 there is nothing else to input though What about the insertion point for the 'pasteblock' command then? Quote
MikeP Posted May 18, 2012 Author Posted May 18, 2012 What about the insertion point for the 'pasteblock' command then? hmm, your right. thanks Quote
